Try these drivers for the Lexmark X5270 printer.
support lexmark com
SOURCE: brother mfc210c printer driver
I believe your brother printer uses one driver for fax/scan and another driver for printing. It might seem like you haven't installed the printer driver, only the fax/scan driver. You should find the driver file and the instruction on this brother.com page:
PS: the driver linked to above is for os 10.4. You might want to search for a different version if you have a newer/older OS.
If the link doesn't work, search for the driver from brother.com's site and download and install the driver by following their 12 points instruction. Good luck!
SOURCE: Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
SOURCE: cant find the disc on my powerbook g4
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
