Question about iPhone Apps
I followed the instructions to replace the AAA batteries, but the outside temp won't properly register.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
I think yolu answered your own queistion there. Its gone faulty, probably in the logic chip. These things blow so easily and are made so cheaply- even the best of them- that when you return them under warranty they toss them in the garbage or recycling and hand you a new one. Its not repairable. Take it back or send it back. Demand a new one. A reputable dealer or company will not argue.
Posted on Mar 18, 2013
SOURCE:
BAR888A -Changed batteries house (1st) & outside unit(2nd.) Now inside unit not receiving signal. Only thing registering is inside temp. Outside unit is also showing temp.
Remove all batteries. Install batteries in outside unit and allow time for it to begin sending temperature. Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit could be defective.
Sep 25, 2018 | Measuring Tools & Sensors
Where is battery compartment?
{ ... ELECTRICALVoltage Requirement: 3 volts
Battery: Two (2X) AAA alkaline batteries
Battery Life: Approx. 30 hours at room temp. (the temp. will affect battery life.)
The standard military magnifying lens can be screwed onto the front object lens of the NM160 for enhanced magnification.
CAUTION: make sure to take the batteries out after operation to ensure proper storage without battery corrosion.
The only additional batteries would be if you also purchased the optional infrared light source. Otherwise there are only 2 AAA batteries.
Feb 10, 2016 | ITT Night Mariner 160 Monocular
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Outside temperature sensor not working
You probably need to replace the batteries. Be sure to follow the LaCrosse instructions exactly to get your Weather Forecaster working properly again
Jun 30, 2013 | La Crosse Measuring Tools & Sensors
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
When AAA came out yesterday and replaced my battery, the service guy had me sign a disclaimer which had something to do with "electronic memory." Meanwhile, several interior issues: the overhead temp gauge...
The electronic memory relates to radio and drivability accumulated adjustments by the computer, not the types of issues that you list with meanwhile area... Look for grounding issues. Why was the battery replaced, was it a cause or a victum?
Sep 05, 2009 | 2000 Volkswagen Beetle
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
iPhone Apps Logo
187 people viewed this question
Top Apps Experts
Marvin
Marvin
ray gallant
ray gallant
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
