HP Photosmart 8450 InkJet Printer Logo
A
Anonymous Posted on Mar 18, 2013
How do I manually clean print heads hp 8450 - HP Photosmart 8450 InkJet Printer
3 Related Answers
myob247
Georgia B
  • 1342 Answers
  • Posted on Apr 27, 2008
SOURCE: HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
  • 6688 Answers
  • Posted on Mar 28, 2010
SOURCE: How do I clean the print heads on my Photosmart
You can get a download of the manual from HP:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=emea_africa&lang=en&product=57595&
The self-clean cycle of the cartridges can be accessed from the LCD or the software on your computer.
To manually cleaning the cartridges:
Remove the cartridge from the printer. Dip a cotton swab in distilled water and squeeze out any excess water. While holding the cartridge by its top, wipe off the face and edges of the cartridge. Do not wipe the nozzle plate (that could damage the cartridge). Replace the cartridge in the printer. Please note: if the cartridge is out of the printer for more than 30 minutes, the ink could start to dry out and not be usable.
The print heads are part of the cartridge.
I hope this helps.
Testimonial: "Clear and succinct advice!"
Anonymous
  • 66 Answers
  • Posted on Mar 05, 2011
SOURCE: How do I manually clean
By manual you mean that it needs windows to clean it right? (you cannot physically clean it yourself) Go to your printers, right click and in properties somewhere you should find "clean heads" somewhere. Try print test after. Should be good.
PC sends job to printer, job shows as printing, printer prints but no ink shows up. The color cartrigdes are low, but the black is full. Test pages don't print, but the cartridge cleaning and alignment...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
After doing a full system restore my HP Photosmart 8450 printer won't print. I use Microsoft Vista.
you may need to re-install your printer drivers. uninstall any old drivers first then re-install the printer. Vista drivers can be downloaded for free from HP.com/support
HP Photosmart 8450 printer and Vista not compatible.
You will need to update your Microsoft Publisher program and you should just update the entire MS Office Suite to be compatiable with windows vista.
My HP Photomart 8450 prints in black sporadically.
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Colour prints not satisfactory
D_foofat,
This link will take you to instructions on cleaning your Cartridge Print Head: http://h10061.www1.hp.com/ccsearch/search?method=viewDocument&redirUrl=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2Fdocument%3Fdocname%3Dc00285228%26cc%3Dus%26lc%3Den%26dlc%3Den%26product%3D402150%26dlc%3Den%26lang%3Den&docId=document%28c00285228%29&uqry=&cqry=clean+printhead&ctry=us&dlc=en&lang=en&qry=clean+print+head
I hope it helps, and Good luck.
k24674
Grand Canyon Tech
Grand Canyon Tech
