Check the battery: Make sure the battery is fully charged and properly connected to the scooter. If the battery is low, charge it fully before trying to use the scooter.
Reset the controller: Turn off the scooter and disconnect the battery. Wait for a few minutes, then reconnect the battery and turn on the scooter. This should reset the controller and may fix the issue.
Check the freewheel lever: If the freewheel lever is engaged, the scooter will not move. Make sure the freewheel lever is disengaged before trying to operate the scooter.
Check the throttle: If the throttle is not working properly, the scooter will not move. Make sure the throttle is fully engaged and that there are no obstructions preventing it from moving.
Check under the back end, generally connect to the electric motor is a lever by one of the back wheels, or in the case of "pride" sometimes they have knob that is lifted or dropped above the housing to engage or disengage the electric brake on the motor. If it is disengaged the scooter will not move by the motor, but you should be able to move the scooter manually, sometimes it gets "between" where it should be! If it is engaged, you shouldn't be able to move the scooter by pushing or pulling. Once your sure it is engaged, turn off the scooter wait a moment, then turn it back on. There is one more reason that may cause you a issue, the scooter can not be connected to the charge cord, disconnect it from the scooter and again turn off the key, and then turn on again to reset the scooter interface. These are both safety connections. Some of the newer ones will also "beep" if these situations are happening, and stop beeping when reset..
that's normal the wheels r locked if u moved the free wheel lever check to c if its back in lock position if it is and the scooter wont move it might b an electrical problem check to c if its got a reset button ....good luck
It could be a battery connection, or maybe your key switch?
Or a connection problem between batteries and the motor controller
or the free wheel switch is on.
