Hi, I bought this lens recently second hand and tried it at close quarters for portraits...........the lens worked brilliantly at all focal lengths. However this weekend I decided to try some street/landscape photography but the lens would not auto focus on anything more than 12 feet away at 35mm-50mm. I tried setting the lens to infinity and then switching the auto focus back on but it still would not AF. When I changed my focal length back to anything from 50mm-70mm the auto focus worked fine again. Any idea's?
SOURCE: The auto focus is not working on my Nikon D50
I assume the AF/M switch on the body is set to AF as well? This has not been mentioned but the D50 has two drive systems for AF.
SOURCE: I have a Nikon 18-70 DX kit lens as well and it
HI I AM SAGHA FROM MUMBAI I AM A REPAIRER AND I THINK UR PROBLEM IS NOT SOLVABLE BY YOURSELF YOU HAVE TO TAKE THE LENS TO EXPERT THERE YOU HAVE TO GET THE AF SENSOR CHANGED.THIS WILL SOLVE YOUR PROBLEM DON'T TRY ANY MORE ADJUSTMENTS WITH CAMERA IT MAY CONFUSE YOU MORE.
SOURCE: My Auto Focus lens doesn't auto focus.
try powering cam without lens then put on. try different lens. if not internal menu should have a lens cleaning option
SOURCE: Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
SOURCE: My 55-200 automatic lens will not auto focus on
From the sounds of things it sounds like a part is worn in the lense, my advise is to contact Nikon and send away to be repaired, they have a great service department. I have used them and they are quite inexpensive to.
