Precor Error Code 20
Error Code: 20
Manufacturer: Precor
Model: All Models
Error Description:
Error 20, Too many Maximum Power Requests in 1 Second - The error 20 observes a treadmill's power bit reading when the treadmill was operating at speeds of 1 mph or less. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 20 indicates that at a speed of 1 mile per hour or less, an excessive amount of power is being demanded from the motor controller for an excessive length of time.
Possible Reason:
Recommended Action:
Precor Error Code 20 20 Too Many Maximum Power Request in 1 Sec
SOURCE: Just moved my precor c966i treadmill (we
it should be a cable that looks like an oversized telephone cable. I can't really tell by the description of the problem if you just can't remember where it plugs into or if you've lost it altogether. There will be a circuit board in the base of the treadmill that will have something that looks like a phone jack port on it. That's where it will plug into. There should only be one port on the lower board that will accept that style of plug.
Testimonial: "This is the exact answer to the problem--after much searching around, I finally found the little box it fit into. the treadmill is up and running. Thanks for your input."
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
