Savco Safe SD 104
SOURCE: i have a gordon digital electronic safe # P45891,
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
SOURCE: locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Testimonial: "thank you very much your help was excelent "
SOURCE: I have a digital electronic safe home
1) Setting non-hinged side "bottom down" on a solid surface, do the exact following operation:
2) Slam the HINGE SIDE of the safe onto a solid floor (bottom feet onto floor), at the same time applying clockwise pressure to the dial.
This resulted in the GORDON P45891 Safe with Dead Batteries and Lost Keys to open up.
Ironically, the Safe keys were found inside, which seems a poor place to store them. Although, I don't know how to use the Safe keys, should they prove necessary in the future.
Now, replace batteries, reset code (using RED reset button), and DON'T STORE SAFE KEYS IN SAFE!!!
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
