Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Electrical wiring for kohler engine
I'm looking for a diagram for a 14hp kohler engine model K321A, spec no. 60258d (garden tractor). Did some work on it and i really need the proper electrical hook ups to the generator and voltage regulator. Generator is heating up and i suspect the wiring is not correct. Is there any possible way to get this diagram?
  • 2 more comments
  • nascarfan240 Mar 16, 2009
    kohler engine 14 horse k321aqs turns over put will not start and no fire at the plug or at coil or points there is some wire behind the flywheel but no idea what it is can someone help me model#k321aqs spec. #60318d serial# 9249970 help me please nascarfan2406@yahoo.com
  • Jim Giesen May 11, 2010
    Is the battery conected up correctly? What tractor is it on?
  • Anonymous Mar 29, 2014
    I have an over crank alarm in my kohler 60 Hz generator marine
    Engine Jhon Deere power tech 4 5 liter
    I tried to reset the generator and the problem remained At the same time I have problem in the oil pressure gage and to be more specific it's showing zero pressure and I change the oil pressure sensor and it doesn't work
    Please advise as soon as possible
  • Anonymous Mar 31, 2014
    looking for part numbers for wiring component
    Novelist:
  • 158 Answers
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
I need a diagram of the electrical system for a cv15s kohler engine that is mounted on a lg 155 John Deere riding mower. The engine will not turn over, even though I have a new battery. The last time I mowed the engine would barely turn over, now it will do nothing but make aquiet click when I turn the key with the brake compressed. Any ideas?
Posted on Jun 28, 2010
    New Friend:
I need to know which color wire on atreetfighter 2 engine comes from the pulse generator its low voltage output!, it doesnt even show you on the wiring diagram supplied to me by peugeot!! please help!!!!
Posted on Jan 25, 2014
2 Suggested Answers
SOURCE:
SOURCE: electrical wiring for kohler engine
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
14HP Kohler engine in JD314 garden tractor has no spark - new coil, condenser and battery - cranks over strong but will not spark
Your problem is electrical. .. there's gotta be a short ... check if there is an emergency shut off switch, under the seat, disconnect that.. the unit is sending a signal to stop the coil from sparking, I'm certain that's your problem!
Oct 05, 2015 | Garden
Show me a wiring diagram for a 13ac762f755,i put a 14hp command,kolher on it tring to wire it up.
Mower side connections At engine connector.
Yellow = Magneto
Red = Alternator DC
Blue = Alternator AC = Lights
Red/Black = Afterfire Solenoid
If the Kohler only has DC output jumper Red and Blue for lighting.
Apr 13, 2015 | Garden
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
How to reconnect kohler goveners
Without the numbers from the engine I can not get you the exact breakdown you need, this might help.
https://images.search.yahoo.com/search/images;_ylt=A0LEVy51DUpT0jUAMvlXNyoA;_ylu=X3oDMTB0Yjkwb3VoBHNlYwNzYwRjb2xvA2JmMQR2dGlkA1ZJUDM3MF8x?_adv_prop=image&fr=yfp-t-301-1-s&va=18+hp+kohler+engine+governor+diagram
If you give me the numbers including the spec number I will get you the breakdown you need.. Best of luck to you, please let me know if i can help..
Apr 12, 2014 | Garden
Jun 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Changing from kohler 12.5 to kohler 14hp
Go to http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Type in your model no. and serial no on mower. Locate correct manual, you will then have to trace wires on both motors and make them correspond.
Mar 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
9,777 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
