When I turn on my MP3 player, the screen changes from black to blue, but nothing else shows up. I'm assuming that I need to charge the battery, and I've connected the MP3 player to my computer, but since the screen isn't showing anything, I can't tell if it's actually charging. Is there anything else I can try?
SOURCE: can't turn on mp3 player
Some MP3 players charge when you connect it to your pc/laptops USB port. What kind of MP3 player is it?
SOURCE: nextar ma933a mp3 player wont turn on
Windows Media Player 11 has support for some MP3 players. It is known to AUTOMATICALLY UPDATE YOUR FIRMWARE . . . which CAN be a bad thing. The reason that it does this, is because it can do ID3 tags and folder structure and all that jazz to some mp3 players.
No guarantee, but this is a KNOWN issue with Windows Media Player.
You would have to reinstall the firmware on your device . . . then next time you use Windows Media Player with your MP3 player plugged in, just make sure that the SYNC options are unchecked in the preferences.
SOURCE: Nothing happens when I plug in my Nextar Mp3 player to the comp.
I PLUGGED IN MY MP3 PLAYER TO THE COMPUTER AND THE SCREEN ON MY MP3 PLAYER LIGHTS UP BUT the normal screen image for when you normally plug it into the computer ISN'T THERE AND I CAN'T ADD MUSIC ON MY MP3 PLAYER.
SOURCE: How do I charge the MP3 Player?
Have you got the cable that go's between the mp3 and the computer ?. If you have then that is haw you charge up your mp3 player, you can leave it hocked up to your computer while it is charging.
SOURCE: Frozen Nextar mp3 player screen
ur mp3 lcd is damaged and the other problem in ur software when u can format it then it will work ok
