Universal MX-900 Remote Control Logo
Posted on Mar 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need mx-900 download - Universal MX-900 Remote Control
Level 3:
Top Expert:
  • Universal Master 76,851 Answers
  • Posted on Mar 18, 2013
Universal Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002491
Points
237762
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Setup code list and instructions to MX remote control is there.
MX 900 says LOADER
http://www.manualslib.com/manual/484745/Universal-Remote-Control-Mx-900.html I hope this can help you get up and running Kerry. Thank you and leave feedback for I am a newbie! Universal Remote Control MX 900 Programming Manual
Why won't MX 900 turn on even after putting in new batteries
The obvious question here is: are the batteries installed the correct way? Here is a web page to download the operator manual:
http://www.universalremote.com/pdf/MX-900OwnerManual.pdf
Also; are your batteries good? are they making good contact? Has the remote been damaged by leaking batteries? Inspect and test.
Do you have the original remote controls for the devices you are trying to control? If so... do they work? Remember... they will need batteries too!
Are there manual switches on the device you want to control? Do they work? Can you turn it on and off?
We are moving through a process to identify which items work, which are good and which are faulty.
Mx-900 remote buttons are stuck
retigh the springs contacts batteries with long pliers for better contacts, and clean it with c. cleaner very well.
2) open the rem.control and clean the keypads from dirty, corrosion, oxide, and bad contacts switch.
proof again,
If the problem persist you must go to the repair shop TV for fix it.ee the block d
God bless you
1helpful
How to reset mx-900 remote to default
download the user manual to your remote control. Click here to download it. It has all detail.
1helpful
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
Remote Control Programming my MX-3000
Hi Jimmy, we do programming for several types of universal remotes all across the country. Once a client visits our site, www.totalcontrolremotes.com, and fills out a new customer form and downloads, fills out, and emails us their configuration we can give them a quick estimate, eta, and mail them back a configuration file. We also are unique in that we offer a lifetime contract for changes made in case the customer adds or subtracts equipment, has channel lineup changes, wants something else set up, etc. We provide many graphical, simple to use and most of all enjoyable custom designs.
Visit our website www.totalcontrolremotes.com for more details. We will be glad to help you with any of your programming needs and do quite a few MX-6000, MX-3000, MX-980, MX-950, MX-900, MX-880, all the way down the line. We also do many other types of remotes as well and I am sure you will find our pricing very reasonable.
Thank you,
Vincent
Total Control Remotes
Universal Remote Programming & Advanced Control Systems
3answers
I can not get my MX-900 Universal Remote to connect to my compute
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
MX-900 Universal Remote Control
you might want to reprogram it with different codes. it's a classic problem.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
