Garden Logo
al kessler Posted on Mar 17, 2013
I have a Bolens BL110 starts fine but dose'nt rev at all
sneubs
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 05, 2015
sneubs
Contributor
Level 1:
Answers
Questions
0
Helped
9621
Points
15
Bolens trimmer sputters and stalls and only runs on half choke? Here's how to fix it.
Look on the top of the carburetor and you will see 2 black screws that are mostly round with a flat side recessed in the aluminum housing. They are flat on top and have no notches to insert a screwdriver. The trick is to turn these two screws 1/4 turn counterclockwise. I have a set of precision pliers and used the fine tipped needle nose to turn them.
The other option is to try and notch the top of them enough so you can use a flat blade screwdriver. You can grind down the surrounding aluminum with a Dremel tool so you can access them better.
You can see in the picture that I scratched across the top of the screws as a reference to see how far I was turning them.
I have a Bolens BL110 starts fine but dose'nt  - bolens-bl110-starts-fine-but-dose-39-nt-1gx55vz5rtv1ddslmtlbezy5-3-1.jpg
Charles Drake
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Mar 18, 2013
Charles Drake
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
8645
Points
21
Probably needs the carburetor cleaned and a new set of diaphragms put in.
1 Related Answer
Andrew White
  • 2239 Answers
  • Posted on May 07, 2012
SOURCE: I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
1helpful
I have a brand new Bolens BL110 Curved Shaft String Trimmer and the cutting head won't stay on. Can I fix it or do I have to return it?
Make sure you have the head correctly located and affixed. If you have, return it.
BOLENS BL110 OPERATOR'S MANUAL Pdf Download ...
https://www.manualslib.com > ... > Trimmer > BL110
Summary of Contents for Bolens BL110. Page 1 BL110 2-Cycle Trimmer Operator's Manual Removing Unit From Carton Assemble The Unit No Tools Required!
Apr 05, 2021 • Garden
My Bolens BL110 weedeater was working fine. All of a sudden, the engine started revving up. The string was still turning, but not very fast.
Your description suggests that something has happened to the drive between the engine and cutting head. Some strimmers are fitted with a centrifugal clutch for easier starting and safer operation.
If your strimmer is so equipped, the clutch is likely to be the component requiring close examination.
How to restring my Bolens BL110 trimmer
Hi!
Please check the manual to this trimmer:
Hope it will help! https://manualsbrain.com/en/manuals/804363/?page=2
Oct 08, 2018 • Garden
The head on my Bolens BL110 weed eater is slipping
Check the drive shaft. Within the drive tube there is a tightly sprung drive shaft, check where this connects to the head of the cutting attachment, it could have a worn drive.
http://www.ereplacementparts.com/mtd-bl110-41ad110g965-trimmer-parts-c-20039_20040_143532.html
Apr 10, 2016 • Garden
Bolens bl110 weedeater runs until I try to cut
Adjust carb. Initial adjustment is 1 full turn out on both low and high side. If it still fall on it's face, turn the low side out and additional 1/4 turn.
Sep 24, 2014 • Garden
5helpful
2answers
May 06, 2012 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
Thomas Perkins
Thomas Perkins
