There must be a specil way to remove these covers
If your refering to the Walbro carb and the little red anti tamper caps then they can be a pain. If you look carefully they have a little tab that sticks out of them and this must line up with the cut out on the carb in order for them to be removed. I use a pair of long nose pliers to take them out, but if you're not fussed about putting them back on then just keep unscrewing the tuning screws, They will eventually break the caps and come out with the tuning screws.
SOURCE: husky 350 chainsaw idle to high
First there is an throttle idle screw that adjust the amount of throttle at idle try turning it ccw until it idles down. If this adj is at its lowest level then adjust the L screw until you get the idle you want. Then try to rev up it should rev up without hesitation if not hold down on throttle untill you get max rpm it it tries to cut out etc. at high rpm adj. the H screw until you get max rpm. then adj your L screw again for proper idle. You may need to do this back and forth for awhile until you get max. performance.
SOURCE: muffler screws are stripped out of husky 350
Most chainsaw shops will install a Helicoil cheaper than you can buy the tools. If I am not mistaken this is a common problem on that saw. Husky dealer might be best option.
Lou
