Car was blowing am2 fuse, found the noise suppressor was burnt out in the distributor, was wondering if removed would it cause any problems ?car runs really sweet after removing and not blowing any fuses
SOURCE: am2 30 amp fuse blowing
check the battery cables for wear and make sure they aren't grounding out on the frame you have a direct short and that is more than likely where it is
SOURCE: AM2 fuse keeps blowing, what do I do
if your am2 fuse keeps blowing your have a short in your ingitor wire that comes out of the distribitor the plug with two wires that runs to the firer wall!
SOURCE: 1994 toyota corolla blowing AM2 30A fuse under the hood
On top of the cover of the fuses it will tell you what that fuse was for. Odds are whatever it is, is shorting out and will need to be replaced.
SOURCE: car wont start
Fuses AM1 and AM2 power the ignition switch.
If you have any other questions, please feel free to respond.
Thanks for choosing FixYa for assistance.
SOURCE: fuse blows for instrument cluster on 97 toyota camry
U HAVE A SHORTED POWER WINDOW MOTOR CIRCUIT, START BY DISCONNECTING THE WIRING TO THE DRIVERS DOOR AND SEE IF IT GOES AWAY.
