The gas tank is full and the fuel gauge rests on empty
You may go to your owners manual and look for a page that discuss about fuel fuse. Smit
Jeep Tops and Jeep
Soft Tops
SOURCE: gas gauge reading empty even when tank is full
Usually if the gas gage does not work yes it is true it may be the sensor if it is electronicly controlled. the sncor will more than likley be in the tank. here is how to remove your gas tank.
To install:
Fuel pump assembly mounting
SOURCE: gas gauge reads empty but tank acts like it's full
I also have a 04 with a 1.8L. same problem. I took the fuel regulator off. It is a black box behind the rear tire under car. It only has 2 bolts to take off. After that there is a couple of vent hoses from the tank going to this box. Unplug them and 1 electrical connection. The electrical connection and one vent is connected to a T connection on the box that you can unplug by twisting on the T. Take that T off and look inside where you unplugged the hose on this T. There is a spring and a little plunger inside this tube. The plunger gets stuck. I took a little screw driver and some PB blaster and worked that plunger back and forth a couple dozen times and it unfroze. Put it back together gassed up just fine. I did not look but I was told regulator can be replaced for 200$. But a can of blaster is cheaper.
SOURCE: 2002 Chevy Suburban: Fuel gauge reads empty, tank is half full
Youre gauge is controlled by a plunger in the fuel tank which is attached to the sensor and the fuel gauge. it sounds like when the plunger goes down half way its either getting stuck down lower then it should. Needs replacing. Any mechanic can do this install for you.
SOURCE: kia sportage fuel gauge unit not working ?
hi this sounds like it could be a couple of things, first the obvious have you checked the fuse? or it might be the relay in the fuse box might need replacing, and the fuel sender unit in the fuel tank, you also can check out the wires going to the sender unit, sometimes you can find these under the rear seat or in the boot/trunk area might be a simple case of one of the wires have come adrift there is a couple of things to check before having the sender unit replaced or the Gage..hope that helps
SOURCE: fuel gauge stops working at half empty and will
you have 2 recalls
pcm update fuel pump replacement
fuel pump module replacement and pcm software
