HP LaserJet P3005 Printer Logo
Posted on Feb 26, 2009
Standard top bin full remove paper
Sir,
when i on the printer then "standard top bin full pls remove paper"
shows massage. I have HP laserjet printer 3005 dn . so how can i solve this problem.
pls help me standard top bin full
  • Anonymous May 14, 2009
    This happens on our printer daily. Push the flap down on the exit tray
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Feb 27, 2009
Anonymous
Contributor
Level 1:
Answers
49
Questions
0
Helped
27553
Points
73
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
1 Related Answer
Anonymous
  • 417 Answers
  • Posted on Jan 13, 2008
SOURCE: standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Printer shows standard top bin full
Where the paper exits, there should be black tabs that lift up each time a page exits. They might be stuck in the up position, or possibly broken. Usually caused by aggressive removal of a paper jam.
Can not print. Standard top bin full shows up on the display
Clean top bin sensor.
Remove back cover., observe a flip moving up & down while paper is coming out & the same was fed into a ir sensor., u can see from back side., clean that sendor with good brush or cloth..
1helpful
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
When i on the printer then "standard top bin full pls remove paper" shows massage. I have HP laserjet printer 3005 dn . so how can i solve this problem.
You have a broken sensor flag most likely or a defective sensor. Sensor and flag located under the top cover in the top right hand back corner. Also check to see if the cable is connected on the sensor and DC controller. If everything is ok, mostly likely defective DC controller.
Often I do repairs on printers because the customer does not use it properly or just plain abuses it. Just read the manual before using.
1helpful
Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
Issues with HP Laserjet P3005n
That means that the output tray is filled to capacity, or one of the students broke the "bin full flag" at the top of the printer.
12helpful
2answers
Standard top bin full remove all paper from bin
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
55helpful
10answers
Standard top bin full error in hp 5200 tn laserjet printer
i have hp 5200 printer
printer shows message top bin full
and not prints what slution of this error
5helpful
Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
41helpful
6answers
Thanks J
k24674
Grand Canyon Tech
Grand Canyon Tech
