Sporatic and making a horrible noise sounds like the cable is full of sand
SOURCE: Speedometer Squeaking Sound
I have a 1997 tacoma with 84,000 miles. i have the same problem and took the instrument cluster out. the problem appears to be with the speedometer cable and i plan on replacing it.
SOURCE: Speedometer Cable is making a high spinning noise
The cable needs to be lubricated. You will need to remove one end, and spray a lubricant like WD-40 or dryslide in the housing of the cable. If this doesn't solve the problem, it's too far gone, the cable will need to be replaced.
SOURCE: how would you tighten the speedometer cable in the
There is a retainer clip that holds the speedometer cable snug in the transmission, that is the only thing you can tighten. Anything else that is loose is worn out and needs to be replaced.
SOURCE: the speedometer started making a
u may need to replace the gear in the transmission to get it to work
