double anon post.
backup one post and read. left or right lights? if both that is HAZARDS stuck on.
cycle the hazard switch , bingo?????
there are 2 fuse, Turn, and HAZ, one must kill the blinking
which one? PULLED.?
you double post and ANON to boot., so here i ask again,.
it dont crank
or cranks ok fast but will not start.????
Sounds like the turn signal switch is bad. It is the only part that can initiate the flashing. I don't think it is going to be loose wires/ connectors because that would stop the light from working at all.
Edit If you pulled the right connector, the light would have to stop, based in any Ford schematics I have, because the power into the switch and the out to the light passes through the same connector. If the light stayed on solid, not flashing, I would say something is crossed, but with the connector pulled, the power and lamp are not connected http://www.xcardiag.com/
Main system control IC fault. Replace it, and initialize it. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Not sure, but I've heard a bad hazard switch can cause strange problems. Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Might need to replace your transmission control module located under your pass side floor carpet. Remove the plastic kick panel to the right of the passenger's foot, carefully pull back as much carpet as you can. There you'll see the cage for the ECU and your trans control unit. The trans computer is the smaller one. Good luck.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
