Replacing tread belt on machine
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
SOURCE: cadence weslo 340 cs treadmill wont engage treadmill
If the transformer does not produce a "hum" the power is either not reaching the rectifiers or the rectifiers have died . Not likely if the machine was running last time prior to being put away. Try physically advancing the tread/belt to set the motor to a different contact starting point since corrosion (ambient humidity) may have dulled the motor contacts(brushes).
SOURCE: Where can I get a drive motor for my Weslo Cadence
Go to iconfitness.com click on customer service then diagrams input manufacturer then the brand name. This should give you the info you need to order your motor if not callthem 1-800-999-3756.
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
