Question about Netopia Cayman 3386-ENT Router
Specific to the Cayman 3386-ent. When I plug my modem straight into my computer, I can get 37Mbps but when I route through the Cayman, I only get 15Mpbs. I'm splitting my signal between my desktop
3 Suggested Answers
SOURCE:
kwondomaniak
  • 30 Answers
SOURCE: cannot get laptop on the internet.
well you gotta make sure that your laptop is not too far away from the laptop; cause there is a distance cappacity. and try playing around with the antennas, and moving it around. i hope this helps a little!!
Posted on May 29, 2009
  • 78 Answers
SOURCE: I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Posted on Oct 11, 2012
Bandwidth
This will explain, doesn't your ISP provide different plans? http://www.pcworld.com/article/158552/check_ISP_speeds.html
Mar 13, 2013 | Netopia Cayman 3386-ENT Router
I reset my Netopia Cayman 3347W wireless router and now my Laptop is not able to use the Wireless signal as it states that the connection manager is set to use only secure wifi but the reset signal is not...
Oct 11, 2012 | Netopia Cayman 3347W-Ent Wireless Router
My wireless router can connect my computer,but can not open internet website.why?
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 17, 2011 | Netopia Cayman 3347W-Ent Wireless Router
How do i change the NAT type to open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
regards
Tom
Jan 16, 2011 | Netopia 1 x 10/100Base-TX LAN, 1 x ADSL...
Can't use Terminal Services through the router, can't vpn through the router
Sounds like a firewall issue on the computer that you are trying to RDP/VPN from, or possibly that these services have not been allowed through the routers firewall.
Log on to the routers web configuration page, and see if there is the option to allow these services through.
Oct 17, 2010 | Netopia Cayman 3347W-Ent Wireless Router
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Netopia 3347 moved to a different location/tel number
If you got the netopia in anyone of the 13 states that ATT controls, then that netopia will work in any other state, not just the phone number it was attached to. We are implementing technology now that it will be phone specific, but most people dont have that installed yet.
All you have to do is reset the netopia, open a browser, type 192.168.1.254 and set it up with the new username and password you created when you got your new DSL service.
spin
Feb 18, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Bought used modem and don t have user name and passord
on the back panel you will find reset button. press and hold for 20sec. So your router will get back defaul settings.
Feb 01, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia 3347 LAN problem
Can you ping them, there may be a type of firewall that is blocking that traffic on the netopia router. Try and ping between computers and see what you have any comminication.
Jan 16, 2009 | Netopia Cayman 3347W-Ent Wireless Router
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia Cayman 3386-ENT Router Logo
37 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
