Nokia Classic 2330 Cell Phone Logo
Nicholas perry Posted on Sep 10, 2017
The phone 2330c stays on only when the charger is fix into the wall socketet
When the phone 2330c is switched on the screen comes on ok ,but after requesting date and time setting it goes off .it only comes on again when you restart . Or when you leave the charger in while plug to electricity. and with that you can even talk the longest ,but immediately you remove the charger from the wall socket it goes off . so whats the solution that problem
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Apr 13, 2009
SOURCE: phone restarts on its own
I tried to switch on my cell with the data cable already attached.It kept on beeping on my pc but cel did not switch on.I detached the cord and switched on my cel.It showed the nokia logo and kept switchin on and off.Later i removed the battery,replaced it back and switched it on.And BANG!!! After 5 minz it switched on!!!!!!!!
Anonymous
  • 375 Answers
  • Posted on Sep 21, 2009
SOURCE: i have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Anonymous
  • Posted on May 02, 2010
SOURCE: Nokia 2330-c hangs
dear sir i have one problam thats is nokia 2330 automatic swich of in 1 min so i need your help plz help m e
Anonymous
  • 1932 Answers
  • Posted on Feb 07, 2011
SOURCE: my nokia 2700 classic phone
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
File Repair Services
  • 827 Answers
  • Posted on Apr 03, 2011
SOURCE: my nokia 5130c-2 phone getting
May be your phone memory card contains the virus.
So scan your memory card using the anti virus installed in your machine.
You can scan you memory card for antivirus using the Avira anti virus.
Please download the anti virus from :
http://www.avira.com/en/free-download-avira-antivir-personal?
Download the .exe file from the link.
Install the software in your computer.
Remove the memory card from the phone and connect in your machine using the memory card reader and scan the card.
2answers
1helpful
Why won't the battery charge?
3 logical possibilities comes to mind: 1) Battery is faulty. 2) Charger is bad, not connected to an active wall outlet or not making good connection with the tablet. 3) There is a software issue, possibly with the application that shows the battery status.
1helpful
2answers
1helpful
How to unlock a nokia 2330c-2 phone
Get the unlock code for NOKIA 2330C-2 at here
Simpleunlocking.com/nokia-2330c-2/rs16wp9/ and unlock it step by step using the instructions below:
Nokia 2330c-2 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 2330c-2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2330c-2 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2330c-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2330c-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2330c-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2330c-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2330c-2
Dec 08, 2011 • Cell Phones
On of swich not working
Does the charging indicates when you insert a charger ? If yes follow the link Nokia 2330c power switch ways - GSM-Forum.Or contact mobile repairing shop.Good luck.Thanks for visiting fixya
1helpful
How do i break the security code on my nokia 2320c
146helpful
7answers
Lost my security code for my phone a nokia 2330c-2
Lost security code 2330-2 how to unlock
Mar 11, 2010 • Cell Phones
17helpful
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
2answers
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
