SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
SOURCE: i am trying to locate a fuse for a Sanyo plasma
thats a 10 amp fast blow fuses rated for 250v
You can get them at any Radio SHack Store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Testimonial: "fast and accurate thanks a million "
SOURCE: 20 SANYO VIZON DOES NOT HAVE MENU BUTTON IN THE TV
The menu button is on your remote control, it is located at the bottom of the input button
SOURCE: what does the power fuse on Sanyo HDTV Model # DP50747 look like
got a 52 sanyo hdtv and it will not turn on anybody know the problem
SOURCE: ysus board number for a sanyo 50'' plasma model dp50747
I just bought a Sanyo DP50747 50 inch plasma. When I pause the tv, then push play (even 1 minute or less) the sound does not start as soon as the picture starts back. I have picture first and no sound for 4 or 5 seconds then the sound continues from that point.
