SOURCE: how to set up wifi on o2 xda atom
In case you use an ADSL modem, its not gonna work.
I had to give mine a static IP address to get the Wifi to work (DHCP
did not work at all). It also seems very slow and the battery life
drains very quickly when you start using the wifi anyway.
hope this helps you....
SOURCE: factory reset O2 Xda Atom Exec Smartphone
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
SOURCE: I need to know about a service centre in Bangalore for O2 XDA EXE
Uccom service center
215/16 gnd floor, knm complex,
28th crs, 2nd blk rajaji nagar, blr 10
Back side of Rajajinagar RTO office.
080-23529344
022-40333999
[email protected]
SOURCE: How i can Format my phone
Go to Start>Settings>System Tab and select clear storage option enter the required code (usually is 1234) and select yes. This will format your phone!
