A
Anonymous Posted on Mar 15, 2013
Lanier LP226CN paper jam
I replace the maintenance kit and the paper is jamming
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Nov 03, 2007
SOURCE: Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
A
Anonymous
  • Posted on Jan 06, 2008
SOURCE: false paper jam
how can i remove the jamed paper
Anonymous
  • 87 Answers
  • Posted on Jun 07, 2008
SOURCE: Lanier lp226cn
Hold the up and down arrows together for 10 seconds, and press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on. Try it. It is a fuser code, and it just might be dirty where the sensor touches.
Anonymous
  • 3 Answers
  • Posted on Jul 02, 2008
SOURCE: 202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Anonymous
  • 7 Answers
  • Posted on Jul 08, 2008
SOURCE: HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Paper jam error
That sucks, I guess you screwed something up.
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
13.20 paper jam
Is this the right door jam? If so, have you checked the pick-up rollers. I had this happen on a machine after I had changed the rollers, but didn't get one of them seated properly, which caused it to slip on the paper. Since the paper sensor behind the door did't sense any paper, the machine assumed a jam. If the rollers were slick, than you might have the same problem. I hope this helps.
In Case You Still Having Problem Then Follow Us For On :
HP Printer Support
I have an hp LJ 9500 and the paper keep jamming
first check for the life of maintenence kit if it expires then
replace the maintenence kit / clear the position where the paper jaamed
in maintenence kit all the roller & fuser replaced .
1helpful
3answers
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Paper jam related to Maintenance Kit
I wonder if you got some of the silicon lubricant from the maintenance kit on the rollers.
Try taking some alcohol or a cleaner such as fantastic, 409 etc and throughly clean all the rollers in the paper tray and along that transport behind the door.
If it isn't getting out of the tray you may coincidently have a smoothe feed roller, if it is feedinf a couple of inches out of the tray and stopping in the lower rollers I suspect a slipping registration clutch. Removing the maintenance kit seems like an odd thing to start a jamming problem. As I said clean the rollers, I guess see if you happened to have gotten a chunk of ink in the paper path from the catch tray.
Is there any damage to the paper? And tears or dents in the page?
Let me know we can resolve the problem.
2answers
Hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
1helpful
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
