Compartment back came off, contact points for battery fell off, can't figure out how to put them back, no diagram found in owner's manual
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
SOURCE: My Salter Electronic scale (3007)
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
