When I start up my machine I get an error message; ER 9. My manual tells me to turn it off and fix the problem, but I have no idea what the problem is I have to fix!? What does ER 9 mean?
Hi Sippe Max-
I found this owners manual link to your Husqvarna H-class 600e sewing machine.
http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/1fd5659e6f37141041256697003e64c0/150dbfd2b9107babc12578010047839a/$FILE/HClass_600E_manual_EN_A.pdf
On page 55 of the manual it talks about what ER9 means. and how to fix it.
Hope this helps.
SOURCE: can't update my new husqvarna diamond embroidery machine
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
SOURCE: I have a
Go to www.sewingmanuals.com and download one for $10, you have to look under Viking not Husqvarna.
SOURCE: Has anyone had an issue with the husqvarna 600e continuously breaking needles?
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. machine could also be out of time
