The telephone was working perfectly yesterday today however when we try to use the handset to get an outside line a message flashes up calling 30 later and we are unable to use the handset
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Norstar M7310 corded telephone
End session and save
worked for me, hope it helps
SOURCE: default volume HANDSET volume on a m7310?
Were you able to get this setup and working to your liking?
SOURCE: meridian M7310-shows outside line in use and cannot disconnect
the easist way to reset that is to reset the system. unplug it for a moment that should clear it.
SOURCE: Meridian Norstar M7310 -- Phone's buttons seem disabled.
unplugging and replugging is the first step. Is your shift button stuck?
Dan
SOURCE: I have a Norstar Meridian with M7310 phones. When
sounds like your telephones not programmed for handsfree.
Programming is done on 7310, 7324 and 7316 type sets.Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
