it shows the last job still printing even after it has printed and continues printing same jobit shows the last job still printing even after it has printed and continues printing same job
when I print a document it prints multiple copies continuously and the document does not disappear from the queue!when I print a document it prints multiple copies continuously and the document does not disappear from the queue!
You could do firmware upgrade, before we look into replacing the formatter board to be sure its not from the Board... Inbox me to put you through the process. [email protected]You could do firmware upgrade, before we look into replacing the formatter board to be sure its not from the Board... Inbox me to put you through the process. [email protected]
You can't post conmments that contain an email address.
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
Is the paper size set on the computer for the size of paper you are printing to? Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
HP LASERJET P1005 PROBLEM: it was out of paper, new paper was installed, but printer wouldn't feed or print
SOLUTION: Lift the top cover of the LaserJet (where the printed paper would come out) and close it again. This resets the printer. Now the printer should feed and print again.
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready. Make sure the paper size is correctly defined.
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
print action does not stop until printer in switched off or out of paper
