Jobo GIGA Vu Pro Digital Media Player Logo
A
Anonymous Posted on Mar 15, 2013
Lost my charger what is the charger voltage - Jobo GIGA Vu Pro Digital Media Player
2answers
Charger output voltage and amp
Search google for a charger for your laptop model and look at the specifications shown for the chargers available. The voltage may also be on the bottom of the laptop and also on the battery pack.
1helpful
Can I charge a tablet with a cell phone charger?
You should check the Voltage and Amperage rate of your tablet's charger, should be same of cell phone.
If you've lost your tablet charger and you are not sure, don't do it. You might fry some circuits of your tablet by Voltage overcharge
Ask someone with a similar tablet for this info, It is on any charger
I have lost my charger what voltage is the original charger?
Just go get a generic charger that fix your phone. And the voltage info is usually on the battery
Apr 02, 2011 • Cell Phones
2helpful
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 29, 2010 • Cameras
1helpful
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Inovix Portable DVD Player - have lost the charger
...first you must make sure the voltage of the player...usualy you can read it in the back panel of the player...example : 9 volt 500 ma....then after you know for sure the voltage you can find an universal charger with at least same output....at the electronic store...make sure you have a same voltage and miliampere !!!
1helpful
Lost ac adaptor
well look on the player it self should say some sort a input voltage they all very then goto radio shack or dollar store find that style charger watch for ac and dc voltage good luck
1helpful
Lost the charger for T5720 cradel, need voltage specs for replacement
HI,
The charger cradle for this model is 220V.
Hope this helps
Top Jobo Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Jobo Audio Player and Recorder Expert? Answer questions, earn points and help others
