Service traction light came on & my chevy cobalt 2008 won't start.
SOURCE: ABS & traction control just went out on 2008 Ford Escape.
Chances are it is a bad ABS sensor. Need to get scanned to know for sure and which one.
Not much i know but I hope that helps.
SOURCE: I need to remove the front headrest of a 2008 chevy cobalt lt
Push the button and pull up on it at the same time
SOURCE: Chevy HHR 2008 LT 2.4. Message ESC OFF, SERVICE
Hello and welcome. the engine reduce power waraning is the key to the other problems. this is normally a problem with the electronic throttle system. the engine control module disables the traction control system when it detects a engine problem, in your case a problem with the electronic throttle system. you shouldnt drive with this concern. this is normally covered under the vehicles 100,000 mile warranty. you need to conteact your nearest dealer for help
SOURCE: Key won't turn in 2008 Chevy Cobalt. Tried moving
now what it sounds like is the key has a sensor built in it the keys cost around 60.00$ but this is most likely what is wrong. the sensor is a security feature with the car if the light glows while trying to turn the car then this your problem :)
SOURCE: traction control off, service traction control,
{: ) Your stabilitrak system may not work properly. The vehicle need to be scanned for trouble codes. In case you get a C0196 code, the recommendation is to reprogram the electronic brake control module. I hope that's the only cause.
