Just bought a Acer Aspire X1700
No Manual came with the computer.. Acer Website has limited instructions on recovery and other items but the speakers have a USB plug and another plug.. There are multiple plugs in the back of the computer to add a home theater but I don't know which of them to plug the speakers that came with the computer into..
I have a similar problem. I found the green plug in my 2 speakers
work fine, but I have nowhere to plug in woofer. can I buy an adapter to hook up woofer or more speakers?
In most cases the woofer plugs into the speaker which contains the power adapter plug, the green plug goes into the PC's audio out (usually a green plug on the back of the unit). When the USB is plugged into the machine the OS should plug and play the new hardware and may ask you to insert a driver disc if applicable.
After the OS has identified the new hardware and installed it you should be able to test additional audio out plugs if you are unable to hear sound from your first choice (again, ideally the green plug). There should also be a line out plug which may work for your purposes also.
If you are still having issues please post the model of your speakers so that we may look them up...
Is this what the back of yours looks like?
