SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
SOURCE: nortel T7316E ringer
It always will. Now you need to go into system programming and program the phone to NOT ring.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
