Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
My printer hp 6300 all in one does not copy. on display appears the write "Reset Power". what i have to do? many thanks
    President:
  • HP Master
  • 990 Answers
Hello sir; I believe your outlet share with so many device,that will cause this problem, one outlet one machine, turn power off and back on.
Posted on Mar 02, 2009
SOURCE:
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
My problem is a weird one. My family has had a Photosmart 3310 All-In-One printer for a while now (I'd say about 3-4 years), and it's worked fine until recently. Now, the light is on around the on button,...
Hi, I suggest you do a full system reset on the printer and see if that fixes anything. Please do the following. Come back and check with me if it doesn't work.
Performing a semi-full reset of the All-in-One
  1. Use the Power button to turn on the product.
  2. Unplug the power cord from the back of the product.
  3. Press and hold the # button and the 6 button.
  4. While holding the buttons down, plug the power cord into the back of the product.
  5. Continue to hold the buttons down until the control panel display goes blank.
  6. Release the buttons, and then use the Power button to turn on the product. The reset information appears on the control panel display.
Aug 12, 2010 | HP Photosmart 3310 Printer
I have HP photosmart 321 all in one and I have
here.. check this out. a solution to your problem.
Semi reset
Full reset
Jul 05, 2010 | HP Photosmart 3210 Printer
0xc18a0001
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart 3210 Printer
I have an HP C4200 Printer-scanner-copier and when it tries to pull the paper in to print it says ''paper jam''. There is no paper in there that I can see.
1. Please visit the below web link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3300218&lc=en&cc=us&dlc=en&lang=en&cc=us
2. select operating system
3. Downloa printing diagnostic utility
4. Run it and diagonize
5. Fix it and restart
If the issue still persists, then
Perform a reset of the HP All-in-One
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. if the issue still persists, then perform the below steps it should resolve your issue.
  8. 1.Power Button + Cancel Button Combo
    2.Enter special key combo 1[Scan] 3[Copy Color] 2[Copy Black]
    3.‘Support menu’ will be displayed
    4.Press the 2[Copy Black] until the display shows ‘Reset Menu’
    5.Press the 3[Copy Color] once
    6.Press the 2[Copy Black] until the display shows ‘Semi full reset’
    7. Press the 3[Copy Color] once
    8.The printer will go off and will power on by itself, else wait for 20 seconds and power on the Printer
  9. Turn on the HP All-in-One by pressing the On button.
Sep 03, 2009 | HP Photosmart C4250 Multifunction Photo...
Hp officejet 6310 all in one problem when I power up
You may need to copy and paste these links into your browser:
Here is a link relating to clearing the paper jam error message:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00743863&dlc=en&product=1119598
Here is a lik on how to do a power reset when all the lights are flashing.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c01059445&dlc=en&lc=en&jumpid=reg_R1002_USEN
Joe
Please remember to rate Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 07, 2008 | HP Officejet 6310 All-In-One InkJet...
HP C6180 AIO Scanner Failure
hi,
The "Scanner Failure" usually refers to the hardware of the printer. try to do a reset.
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If the issue still not resolve, please call HP 1-800-474-6836. Also check the warranty status of your printer.
thank you so much.
adonscott
Jul 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
130 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
