There does not appear to be a Model C270 in the hp photosmart printer models. Do you mean it displayed a "C270 error code" in what Model No. Printer? The error code C270 indicates a paper jam/misfeed error.You possibly have paper remnants still inside Machine. You could remove drawers from machine, and look inside for remnants of paper. Maybe try turning machine off and on using red switch at knee level. If there is truly nothing blocking a jam sensor, then problem is likely a bad sensor. 99% of the time HP does not make replacement parts available to out-of-warranty printers. That's why I had to dump my C5550 HP Photosmart All-in-one printer; my office machine repair business could not get the replacement sensor! Remember: "Brother model" offer free toll-free phone tech service for the LIFE OF THE PRINTER! That's why I bought a Brother this time!
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Step one: Remove any loose paper. Step two: Clear the jam from the back of the All-in-One Step three: Clear the paper jam from the front of the All-in-OneStep four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Found this on the HP Web site. Issue: The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK '
displays on the product.
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Get Instant services and solution for your HP Printer support. Printer services USA is here to fix your printer anywhere anytime, just call us on our toll-free printer number +1 866-918-4391 or for more visit our official website
https://www.printsupportusa.com/
