Computers & Internet Logo
Posted on Feb 25, 2009
Creating a daily time record system using vb.net 2005
1 Related Answer
Anonymous
  • Posted on Feb 09, 2009
SOURCE: How to create a Computer aided instruction system using VB
if you have some knowledge about VBasic you can create simple programs using label,textbox,progress bar,combo box use your logic to make it beautiful..
1helpful
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
4helpful
2answers
Free visual basic source code salary database sample
you solution is her
Building Websites with VB.NET and DotNetNuke 4/by Daniel N. Egan (Author), Steve Valenzuela (Author), Michael Washington (Author)
Description
DotNetNuke is an open-source Content Management System and web application framework. DotNetNuke has taken the Microsoft world by storm and now at version 4, its community has grown to over 200,000 users. This book covers virtually everything you need to know to get your DotNetNuke website up and running. Concisely written and with clear explanations, this book is covers installation, administration, deployment, site creation and all of the basic built in DotNetNuke modules. For developers, chapters on the core architecture, skinning and custom modules, including coverage of the DAL+, give you the skills to customize and extend your site. The book starts off by giving you a deep understanding of working with basic DotNetNuke sites, guiding you through the features and giving you the confidence to create and manage your site. After that, you will journey to the heart of DotNetNuke, and learn about its core architecture. Always concise, relevant and practical, you will find out what makes DotNetNuke tick, and from there, you will be ready to customize DotNetNuke. Developers will enjoy the detailed walkthrough of creating a new custom modules. Special emphasis is given to the DAL+, an extended feature set of the DotNetNuke Data Access Layer (DAL). You will see how to create custom modules with the DAL+, and invigorate your module development. Web designers will enjoy the material on skinning, helping them to create a new look for their site. You will learn about creating new skins, and packaging them up for easy deployment. You will master all of this as you leap into the development of a DotNetNuke 4 site. This book will give you the skills to create and manage DotNetNuke websites as quickly as possible. You will:
* Install and configure DotNetNuke
* Master the standard modules
* Understand the core architecture of DotNetNuke
* Explore the inner workings of DotNetNuke modules
* Extend DotNetNuke using the DAL and DAL+ to create powerful custom modules
* Create your own skin using a HTML Editor
* Find out about where and how to host and deploy your site
You can use this book to help you set up and administer a DotNetNuke portal, even if you have a limited knowledge of ASP.NET. You will learn how to setup and administer an example site, stepping through all the tasks to ease your learning. If you are a developer, this book will help you extend the DotNetNuke portal by first helping you understand how the core framework works and then show you how to create custom modules and skins. A rudimentary knowledge of VB.NET programming is assumed, but the emphasis is not on becoming a better VB.NET programmer but on taming DotNetNuke. This book has been written for both the beginner wanting to set up a website and also ASP.NET developers with a grasp of VB.NET who want a deeper understanding of how to work with DotNetNuke. To work with the DotNetNuke code, you will need access to Visual Web Developer Express or Visual Studio .NET 2005. No prior knowledge of DotNetNuke is assumed.
download link:
http://w14.easy-share.com/1701584071.html
or:
http://dep
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
3helpful
STOCK REGISTER
Ur answer is simple.
Just keep a common database on internet for all stores & create website (ASP or PHP) or web based application(like Vb.Net or VB) much preferred.
so any sales occurs, it would be reflected across all stores,
so you can calculate total sales & remaining stock any any time and sort it or aggregiate it daily, weekly & montly..
Problem of creating the master page in asp.net vb
Hi galondhe
I'm sorry It's not that clear what your problem is.
In Dreamweaver you save the page as a template which you can then apply to subsequent pages. Are you creating the asp.net page with all the data in it, then saving as a template?
Visual web developer uses master pages. You can always create the page in Dreamweaver and then take it into VWD to create your master.
I need a little more info to be able to help you.
Pls hepl me wit Excel VB integration
you can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
2answers
Create a media player playlist
You will need to give me more information, Because I cant provide any codes without knowing your Programming language.
Plus what type of software you are using to complie your project?
How could i create the reports in vb.net step wise from dataset? acutually i want to prepeare the reporting for printing and also please guide me how to take the data abck on the other partation from my...
usually if you are using vb.net to make a application, it must included the crystal report component. you can use that component to create a customized reports. after you search the component but you cannot find it, maybe you need the crystal report application to create. Trying to find a crystal report application and install into your pc. you must be able to create a report after you installed this program.
2answers
Vb.net2005 flexGrid
http://blogger007007.blogspot.com
Here you can get download links for 18 GB of engineering and programming books. Just do a search of "visual basic" or "2005".
Installing SQL server and VB.NET on VISTA Home Basic
installl SQL SERVER 2005
Vb.net is fine its your sql that will mess things up
BTW visual studio come with an SQL server
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
