Hi Chas,
sounds like you have a piece of hardware that has a bad driver. If you connected something recently, try disconnecting it and then start your computer. If it starts, then you will need to find the correct driver for it before you attempt to hook it back up again.
If that does not solve the problem, try unhooking all hardware, except for the hard drive with the operating system on it. If it starts normally, then you can turn your PC off and hook up one piece of hardware... start the PC... turn it off again... hook up another... start the PC... etc. until you find the hardware that is causing the problem.
If it does not start with only the operating system hard drive attached... then, the hard drive may be defect. You can take it out and put it in a USB casing and hook it up per USB to another PC... if you see the data on it, it should be ok (just in case, this would be a good time to backup any data on it that you may need). If you do not see the hard drive in Windows explorer then it is probably defect and you will need to purchase a new one.
Hope that helps
SOURCE: Compaq Presario 5000 start up problem
Follow the instructions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=96382&prodTypeId=12454&prodSeriesId=96382&objectID=bph07173
SOURCE: COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
SOURCE: compaq pesario C300 not starting
USE ORIGINAL WIN XP CD TO REPAIR OPPERATING SYSTEM...IT WILL WORK FINE
SOURCE: compaq presario sr1313cl pc desktop will not boot
Hi there
can u try to boot into safe mode f8 if not boot into bios than go to your harddrive area and see if it can find your harddrive and try the default settings and save and reboot also make sure there is no cd rom in the drive and there is no floppy in the drive
