SOURCE: need viper 7752v owners manual
Here is a quick manual for the setup options and pairing that I put together
.http://www.the12volt.com/installbay/file.asp?ID=1171
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
SOURCE: i have car infiniti G35 my alarm viper 7701 v sst
You may need to adjust the sensitivity of the sensors.
SOURCE: I just received a brand
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
SOURCE: how to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Hello, am glad to share this information , if your viper remote is reading the word valet , this is what work for me. Locate your blue light that blinks , right next to that is a reset button. I pressed that button three times , and it work likes its brand new.
