Weber Genesis Silver B Grill Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to convert to natural gas.
Want to convert to natural gas. weber does not show a natural gas manifold. Any suggestions?
  • Anonymous Mar 15, 2014
    have Weber S310 natural gas grill will only heat up to 450 deg.
  • Anonymous Mar 27, 2014
    I have the kit I want instructions to do it
Richard
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jan 09, 2015
Richard
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
13138
Points
33
You need to see if there is a model of your Weber that has Natural Gas. Then try and find that models replacement parts. If there is no such model, then it is a harder conversion as you need to change the Jets and the Pressure Regulator. Not just the Jets as some places state...
NOTE: Weber no longer offers or support conversion kits. If you do any conversion it will VOID you warranty!
That said, if you can find the parts online for the Natural Gas version of your grill you can convert it yourself if you are mechanically inclined.
You will need to change the JETS and the GAS REGULATOR. Unfortunately they do not sell official Weber Gas Jets alone. You will have to by the complete Natural Gas Manifold, valves and all as well as the Regulator...
Make sure you are comfortable with all of this... Leak testing etc...
You may have luck finding parts at:
http://www.ereplacementparts.com
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Feb 25, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153382
Points
8370
The only thing you can do if Weber doesn't have a natural gas manifold for their grills , is to buy one that will fit. They use propane on outside grills because of the stability of the gas. Natural gas will blow out much easier.
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 • Grilling
2answers
Convert new Weber gas grill from natural gas to LPG. Can it be done safely by a gas pro? Who can provide needed parts, i.e. gas injectors?
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/
1helpful
2answers
Where can i purchase a weber spirit conversion kit?
That said, if you can find the parts online for the version of your grill you can convert it yourself if you are mechanically inclined.
You will need to change the JETS and the GAS REGULATOR. Unfortunately they do not sell official Weber Gas Jets alone. You will have to buy the complete Manifold, valves and all as well as the Regulator...
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
3helpful
4answers
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
I need to convert my Weber Genesis Silver B grill from Natural gas(NG) to Propane (LP). It is as simple as replacing the NG manifold and valve assemble with the NG one BUT Weber wont sell it to me...
I would contact a propane distributor, They should be able to locate the part. I don't know where your at but the one in my area (Central Oregon is Ed Staub and Sons )
5helpful
2answers
Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
1helpful
2answers
Kit for converting weber genesis silver c to natural gas
Some grills do not have conversion kits, if your grill is labeled as dual fuel you can contact weber and get a kit for it.
Top Weber Grilling Experts
Paul Carew
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Weber Grilling Expert? Answer questions, earn points and help others
