Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
A
Anonymous Posted on Mar 14, 2013
Sony kdl-46bx420 : tv will power on, has sound but know picture. went out while watching.. set is 13 months old.. had perfect picture untill this.. any ideals on what it could be and possible cost..
doug chapman
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jul 25, 2019
doug chapman
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
329
Points
The capacitors on the power supply are bad they mushroom out at the top of the capacitor replace all caps with gold rated or silver rated high speed capacitors that can discharge at the much higher frequency generated by the power supply I use a higher voltage and I have noticed caps that have 12 volts applied to them and the caps are rated for 10 volts, because of the caps being under rated voltage wise the caps will work for a time then from over heating of the caps they will mushroom the top of the caps I have been repairing televisions for 47 years of my life since they had tubes in them, the caps with a black stripe or white stripe are not rated for 15,000 khz these caps sold at Radio Shack are only rated for 30 cycles the frequency of all switch mode power supplies is much much higher than that of a capacitor run by a power transformer, thank GOD that transformer has been replaced by switch mode power supplies that use the PWM technology much more efficient and effective Only use the gold or silver rated high speed caps to replace all caps throughout the HD TV and you can then sign your name to the invoice as being "repaired" I know exactly how PWM switch mode power supplies work you have to work with them from the secondary to the primary and I have repaired 1000'2 of these units not only for TV but printers, UPS, audio power amps, any thing with a PWM switch mode power supplies.. And I am a Certified Electronics Technician/Engineer.
5 Related Answers
HDTV GURU
Jay Henderson
  • 261 Answers
  • Posted on Feb 01, 2008
SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Anonymous
  • 1077 Answers
  • Posted on Sep 03, 2009
SOURCE: 13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Anonymous
  • 148 Answers
  • Posted on Feb 03, 2010
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Sony KDL-46BX420 TV has a black screen with sound.
Inverter board powers the back light leds.
I wanna fix my sony bravia lcd kdl 46bx420 myself
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
1helpful
Hi..I own a sony bravia 40 inch LED color tv model number kdl-40ex600...i've only had it for about 5 months now and it was working fine..up until I was watching a movie and the picture went completely out....
one of the power boards inside the tv has gone, which is why its blinking 5 times, which one it is i cant tell without using a multimeter on the tv. IF its only 5 months old you should ring up who you got it from and get them to fix it, as it will cost quite a bit to repair.
Sony tv kdl-46vl130, Turn the tv on, half of the picture is dark, leave the tv on for about 20 minutes, and the tv is perfect, and stays perfect no matter how long is watched, Turn the tv off, and come...
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
2helpful
Sony TV flashes 13 times and stops
I, too have a KDL52 also less than 2 years since purchase and have the same problem this morning 2009 Oct 2
4helpful
2helpful
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
