Chair is fully charged. After going a distance (not long enough to even lose one green light) it shows only 2 red lights. A couple of times the first green light would go out, then a while later the second one would go, then all of a sudden it's down to those two red lights again - but the chair still works fine. After charging it again, the same thing happens. Will I be stranded one of these times?
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
SOURCE: batteries aren't charging up. Chair want go.(Golden Compass)
That`s most likely your problem. When left uncharged for that long of a period,the batteries will discharge below 12 voltDC. The charger only recognizes 12 volts and up. So the charger can`t bring your batteries back up over 12 volts. You will need to get them on a slow charger,like a car charger or have them replaced. If you know someone or have a voltmeter,set it on DC and check each battery. If it is below 12 VDC,they need to be put on a slow charger or replaced.
SOURCE: Jazzy 1121 power chair won't go
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Testimonial: "That was the problem, Thanks !!!"
