Router is working A-ok - have 2 other computers using it - when I go in to troubleshoot it tells me that WIFI is turned off ? Was working fine when I turned computer off yesterday. It is definitely showing a red "x" on WIFI accessible. It does show my NetGear Router but will not access it. I tried using the WIFI Key - nothing. Any suggestions?
SOURCE: Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
SOURCE: Monitor not showing anything
Spilling water or any liquid fries components, so this is going to be hardware replacement instead of an easy software fix. Let's perform an easy test to see if the machine is working properly, and narrow down the source of the problem. Connect an external monitor to the laptop, If everything works properly on the external, then the screen is fried and will need replaced. If you still have a black screen with the external, then the video card is fried and will need replaced. On some models the video card is integrated into the motherboard, and the motherboard will have to be replaced in order to fix it. Try this and let me know.
SOURCE: screen back light turns on but nothing else is displayed.
please dial this no once for HP help 18004746836
SOURCE: I have a Toshiba Satellite
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
[email protected]
SOURCE: Toshiba C675-S7200 Manual Download
The manual can be located at: http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su3131314/GMAD00278010_Sat-SatProC600_11Mar15_updated06272011.pdf
Hope that helps!
