How do I unlock the scanner
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
Front of the Xerox 6110MFP howing paper output tray and control panel.
Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
I use MFP Twain driver fromhttp://www.scanworkssoftware.com/twainim... and it works great with this Phaser 6110 MFP
THIS WORKED FOR ME. BUT REMEMBER TO RESTART THE PRINTER FOR IT TO WORK
On the left side of the device should be a mechanism to release the scanner
SOURCE: how can you reset the waste toner counter?
Exactly the same problem over here ;-( When replacing the toner recently i forgot to switch of the power, so no reset. I can't find the reset option in the menu, resetting aal settings did not solve my problem.
SOURCE: Please, send me the firmware for Xerox 6110 MFP
firmware to have changed only very extreme case!!! no to reset image unit
SOURCE: My Xerox phaser 3300 mfp
Look under the scanner area-Where the finished paper copies come out- There is a little green Tab. Pull Green Tab forward.
I have the same problem but there is no release button on the left side of the device
