SOURCE: How do ichange the time on Panasonic KX-T7431??
MUST BE DONE FROM EXT.101
1.leave handset in the cradle
2.Press "Program" button
3.Dial *#1234 (star pound 1 2 3 4)
4.Press Sp-phone button 3 times
5.enter the correct hour on the dial (2 digits)
6.press the button (in the lcd window to advance to minutes)
7.enter the correct minutes
8.press auto dial/store button
9.pick up hand set/ hang up hand set.
SOURCE: Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
SOURCE: I am tring to figure out how to program extensions
A 773x phone has 24 buttons, 12 are lighted and 12 are Feature. If you want to reassign some of the lighted buttons as extension buttons on the phone, you can press PROGRAM 1 + ext no STORE and that will give you a busy indication whenever that extension is off hook.
You can program the right side buttons to speed dial the extensions by just pressing PROGRAM ext no STORE. It will dial the extension when you press it if you have intercom dial tone.
How the button behaves is dependent on which system the phone is attached to. In a TA, you have to start with dial tone on the intercom. In a TAW/TDA you don't.
Carl
SOURCE: Change time on KX-T7730
With the handset on the cradle press Program * # followed by the system
password ( default is 1234). Now press 000 and then Sp-Phone.Enter the
year and then scroll to the month with the right scroll key (located at
the right bottom corner of the phone). To change the month use the AUTO
ANS / MUTE button. Now scroll right again and change the date and day.
To change the day again use the AUTO ANS / MUTE button. Now scroll
right again and the time will appear. Set the time. To change am/pm
scroll to it and again use the AUTO ANS / MUTE button. Press program to
exit program mode and your done.
Please rate this answer if it was helpfull
Thank you.
SOURCE: How do I change the time on a KX-T7730 phone?
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
6. Press PROGRAM to exit program mode and you
are done.
