Go to a local shop and ask them to test the sat nav with a different power adapter, so that you can find out if the problem is the sat nav or the power adapter.
I can't power up my satnav. What can I do?
The answer depends on your vehicle but here are some suggestions:
click this link below for more details
http://www.halfords.com/webapp/wcs/stores/servlet/FAQDisplay?storeId=10001&langId=-1&catalogId=14551&categoryId=173000&acCategory=true
Check out proper is any of the button got pressed or stuck up internally.and also check out keeping it in the charger.
First switch off and switch on and see it works .
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
I can`t reset the unit as it can`t be turned on
