Question about HP Compaq Presario F750US
Factory settings on my laptop
How do i restore my e system 3085 notebook to factory settings? i need to do it thru the bios screen
    New Friend:
I have the same looking laptop but my doesnt have that f11 key showing and i cant use my laptop it wont let me into the main screen that has the internet or any of my programs on it
Posted on Sep 22, 2012
    President:
  • 2,653 Answers
It's usually F11 or Fn+F11 at the bios startup screen to enter recovery mode.
If that doesn't work, let me know.
Posted on Feb 24, 2009
SOURCE:
How to restore factory setting of toshiba satellite pro c650.note that laptop bought without os preinstalled and oem os has been installed.pressing zero key does not work.i can not select bios option as my...
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jun 15, 2012 | Toshiba Satellite Pro C650-Z2510T Notebook
Where do I find the recovery partition on my toshiba l645d laptop with windows 7?
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one).
your notebook.
5. Select Recover to out-of-box state.6. Click Next again.
Feb 24, 2012 | Toshiba Satellite L645D-S4050 Notebook
Hi i have a trojan on my acer 5315 laptop how do i restore it to factory settings thanks
Welcome to Fixya. Here is the standard Acer Recovery Instructions
1. Power on the machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
If this wont work you need to use the recovery cd of your system. Take note that if you do the reocvery process all files will be deleted and the system will go back to default or factory state.
Thanks for using Fixya.
Mar 03, 2011 | Acer Aspire 5315 Notebook
I want to restore my Toshiba Satellite Pro to factory Settings, and I don't have the recovery CD.... The specs: A105 Processor: Intel(R) Core(TM)2 CPU T5600 @ 1.83GHz Memory (RAM) 32-bit Operating System...
Set BIOS defaults
  1. Press the [F1] key.**** Bad RTC battery ****
    **** Bad Checksum (CMOS) ****
    Check system, then press [F1] key
  2. In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | Toshiba Satellite Pro L300-EZ1005X...
Reset acer laptop to factory settings
During the system bios boot press and hold ALT + F10, that should start you into the system recovery options.
Oct 30, 2009 | Acer TravelMate 2300 Notebook
How do i restore my lab top its a dell inspriron 1501 wit vista
When you first boot go into the bios by pressing F2 and change to boot sequence to boot off of the cd-rom. Your going to need the Dell Password override cd. Find that and stick it in the drive. Boot up the system and as soon as it says press any key to continue, press any key and it should boot up into a dell windows restore screen and it will ask you if you want to restore the laptop, choose yes and go thru the prompts and it should allow you to restore the laptop to factory defaults.
If you have problems let me know and we can try another way.
May 08, 2009 | Dell Inspiron 1501 Notebook
Restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Apr 13, 2009 | Acer Aspire 4520-5141 Notebook
Factory restore
On a laptop there is no factory setting reset option (unless you mean bios reset ). To get the laptop back to the initial 'as new' condition you need to re-install the system using the recovery disk on startup. Put recovery cd 1 inside laptop cd drive and restart the computer. Follow instructions for complete restore.
If you do complete restore you can lose all your data.
Here is also the user guide :
Satellite L350 Series User’sGuidecheck page 150 onward for other system setting problems
Jul 06, 2008 | Toshiba Satellite L25-S119 Notebook
Factory settings
When you first turn on your computer, press the F10 key until it boots into the recovery partition. Once there, select advanced then follow the onscreen instructions. Warning: This will erase all of your data.
Some newer HPs use a different key then F10; if F10 doesn't work, then look on the screen it should tell you which key to press to start recovery.
Jul 03, 2008 | HP Pavilion dv9000z Notebook
HP Compaq Presario F750US Logo
335 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
