Dremel Variable - Speed Multipro Rotary Tool 395 Logo
Posted on Feb 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dremel model 365 type 1 collet lock latch is worn out.
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Feb 25, 2009
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1311147
Points
5445
I would go to Dremel.com or call their help line at 1-800-437-3635 and speak with one of their specialists.
2helpful
How do I change the drill tips on the Dremel 370 6 model? Can't find the instructions. Thanks
There should be a shaft lock button near the tip end of the tool and you need a small spanner wrench (included with the tool) that inserts into the collet sleeve hole and is turned CCW (looking at the tool end) to loosen the collet itself. Tap on the tool end lightly to help loosen the bit. Hope this helps!
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
3helpful
Can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
3helpful
3answers
I have a Dremel 300 and the shaft lock assembly isn't working to hold the shaft so I can get the collet nut loose. When I try to get the collet nut loose while holding the button of the shaft lock the...
The "nub" on the shaft lock assembly (internal) has worn down and the assembly needs to be replaced.
If you feel competent to open your Dremel yourself (and it's not on warranty) then order the shaft lock assembly from Dremel (early 2011 price: $1.25, not sure how much postage & handling might be). After opening the tool you will find a metal ring and a small piece (the lock) which it holds in place around the shaft where the lock button is located. Remove the old pieces and replace with the new ones and reassemble the tool.
Otherwise you can send the tool to Dremel to be fixed.
I have a Dremel 300, i think, lol.. standard Dremel... To losten the collet nut, you have to press down a button that locks the spindle so you can loosen it.. the spring and *** have stipped and it won't...
call dremel and ask for the part need you model number so have it ready Dremel Service Center Dremel Authorized Service 4915 21st Street 4631 E. Sunny Dunes Road Racine, WI 53406 Palm Springs, CA 92264 Phone: 1-800-437-3635 Phone: 1-800-275-2052 1-262-554-1390 1-760-327-3003
1helpful
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
2helpful
3answers
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
