It turns while washing okay, but no matter what I set it on, it makes a vibrating noise and won't drain or spin. The light blinks off and on too.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first. Remove the front
lower panel, screws underneath. Be
prepared for water, drain out from drain hose.
Check filter for clogging, clean out.
Sometimes when the load is unbalanced & the machine cannot
adjust
the load it stops. To avoid this make
sure your wash is mixed with big and small clothes.
If
this does not work remove the rear panel & check belt, should have
half
inch ‘give’. Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever
the
motor back with a screwdriver. Check the
motor brushes (at terminal end of motor), if they are any shorter than 1
cm
replace brushes.
Try
these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
