Computers & Internet Logo
A
Anonymous Posted on Mar 12, 2013
How do i change time on my polycom phone model 2201-15942-001
I need to change the time on the phone
Should message light be on always ..solid not flashing ...
Constant red means it is set and ready to record messages after x amount of rings. Flashing red means you have a message.
Please always include the model number is such questions and I can find you a manual. Polycom has lots!
https://www.google.com/search?q=Polycom+phone+manual
7answers
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
On Polycom 335 how do I reset voicemail for new employee
"If you need to remove the resource files from a phone at some later date-for example, you are giving the phone to a new user-instructions on how to put the phone into the factory default state can be found in 'Quick Tip 18298: Resetting and Rebooting SoundPoint IP, SoundStation IP, and Polycom VVX 1500 Phones' at http://support.polycom.com/global/documents/support/technical/products/voice/SoundPointIP_Resetting_Log_Files_QT18298.pdf "
http://supportdocs.polycom.com/PolycomService/support/global/documents/support/setup_maintenance/products/voice/spip_ssip_vvx_Admin_Guide_SIP_3_2_2_eng.pdf
One of our Polycom 550 phones keeps randomly
It is not your T1. The T1 only controls the internet, not your local LAN. How old is the phone? It could be a bad phone....What system is it installed on?
2helpful
Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
2answers
Dead Polycom 501
u have the cable plugged in backwards
check it
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
2answers
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
