Hp mini 110-3000...
Sounds like the hard drive isn't working. check in the setup bios of the machine to make sure it is recognized as the main boot device. It should be second in order so that a flash drive could start it up if plugged in. It would be third if you have a CD which minis usually don't. If it lost the date/time and settings, the backup battery is bad and needs replaced.
SOURCE: I have a Dell Latitude e5500. when booting the
You have errors in the boot section, not allowing any of the GUI's to run.
When the system starts press F8 and when you get the menu select Recovery.
That will fix it.
SOURCE: My Gateway 4540GZ boots to black screen w/cursor...help
remove the and test it H.D.D or change the RAM ,
SOURCE: One minute it was working fine, the next it was a
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
