SOURCE: i have jus brought a
I have just spoken with Acer Support, and where M5100's have dedicated graphics cards, this disables the onboard graphics including the HDMI.
The onl way to eabl the HDMI is to remove the dedicated graphics card, and revert to shared graphics which will enable HDMI. The problem with this, according to the support technician, is that it will slow the computer down considerably.
Why the hell do Acer do this? They must know this is an issue in the first place; absolute idiots.
SOURCE: Need correct SATA driver for a Acer Aspire M5100
All manuals and drivers for your M5100 here:
http://support.acer-euro.com/drivers/desktop/aspire_m5100.html
Best wishes.
SOURCE: acer aspire t130 amd athlon 64 3200
http://support.acer-euro.com/drivers/desktop/aspire_t130.html
http://support.acer-euro.com/documents/manuals/desktop/manual_aspire_t130.html - Manual
Links to manuals
SOURCE: Acer Aspire M5100 AM5100-U5313A AMD 4400 will not
Could be. Sounds like a repair shop issue if no system info is appearing.
This may be pointless, but try it anyway: -
It shows symptoms of RAM error, except it lacks warning beeps or led flash usually associated with this. Some PC's don't have this function.
Remove all RAM and replace one stick only, presuming you have at least 2 sticks. then try the same thing with the other sticks, one module at a time.
It's rare, but RAM does fail and it causes these symptoms. Also, if RAM is mixed and incompatible, this would also occur.
Mixing RAM may also kill the good RAM.
Next, check your PSU voltage readings ie 5v rails and 12 volt rails with a good quality multimeter. Or you might try another PSU.
Really need to have it physically in front of me to give a better answer.
SOURCE: How do I take apart case of Acer Aspire M5100 to
http://www.youtube.com/watch?v=kpiFF9ipmAo
please watch the above link - it will give you a generic idea of how to remove the case - the screws will be what holds the side in place. It is EASY - just don't over complicate it - - best of it
Gary
