Televison & Video Logo
A
Anonymous Posted on Mar 12, 2013
Symphonic iwt3206 need manual
Where is the hdmi connection?
The Ilo IWT3206 is a CRT type TV; it does have an ATSC tuner to support digital OTA TV signals. It doesn't have an HDMI port. The best input it has is the component video in. There are HDMI to component converters. However, most of them have issues with digital rights management protections (HDCP). The manual for the Ilo IWT3206 is available from the manufacturer (Funai). Their support page is at http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is http://www.funai-corp.com/support/om/IWT3206.pdf .
I wish that I had better news for you. If you have a different model, please post a comment or a new question.
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
1helpful
Manual for Symphoic VCR SL2940
Funai made this VCR with the Symphonic brand name. The Funai Service support site, http://www.funaiservice.com/manual2012_search2.php , has the manual. The direct link is http://www.funaiservice.com/manuals/SYMPHONIC/SL2940/SL2940.pdf . You will need Adobe Reader or a similar product to read or print the manual.
I hope this helps.
Does ilo model #IWT3206 television have reset button ?
It does not appear to have a reset button or any type of reset menu option. http://www.funaiservice.com/manual/ILO/Manual/IWT3206.pdf Some TV's will reset by simply unplugging them from the AC outlet for 1-2 minutes then plugging them back up.
Message says see first page of manual
Do you have a coaxial cable attached to the antenna in on the TV? The TV has an ATSC (digital OTA) tuner and a NTSC (analog OTA or CATV) tuner. The initial setup wants the incoming antenna in signal to be present (this is the only message on the front of the TV manual).
This TV was built by Funai and the manual is available from Funai's support page: http://www.funai-corp.com/support/manuals.aspx . Since Funai makes TVs for a number of brands, the best option is to search for the model number (leave off the brand name) in their search box. The direct link to the IWT3206 manual is http://www.funai-corp.com/6pdf/om/IWT3206.pdf .
I hope this helps.
I have a symphonic tv VHS HQ 1999. Need cord.
http://www.symphonic.us/support/manuals.aspx
the cord you need is ac or for car cord? in the manual at page 6 you wil find the cord model and code for this.
I need a service manual for a Symphonic VCR Model SL2840.
Since I can't find a service manual, I gave up. Thanks for your reply.
3helpful
2answers
Need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
Symphonic codes for rca rcr450
Download the manual and look at the back pages =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Codes for Symphonic TV on Page 39
Symphonic TV 1026, 1033, 1038, 1046, 1155, 1189
Codes for Symphonic TV on Page 40
Symphonic VCR 2026
Good Luck!!
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
